Hi,I'm new to Lectora and currently encountering problems with targeting a label within an swf. I simply want to use Lectoras "go to label" Flash command, either by putting it on an action or a button, but it does not work. This should really be a simple matter and I have not found any other posts on this. So, I have a few questions: 1. What is the syntax when specifying the label in the name-field (under the flash command in an action)? Should it be "my_label", my_label or some other syntax that is not specified in Lectoras help section (not much help there ...)? 2. Is there something else I´m missing? My swf is imported into Lectora as an animation. The label is in the main timeline in Flash, and there are some movieclips with their own timelines as well. By the way, I´m using Lectora Publisher 2008. It is a Swedish version, so please overlook any terminology that might not be correct (and because my English might lack some too ... ). Thanks /Carina
