I'm trying to create a form that asks 1 question with 4 responses. Each response should cause the user to jump to a particular page, or even to show one text box or another on the same page. I can do this by adding 2 actions to the continue button, but only if the Radio buttons are not contained within a group. I would like users to only choose one of the four options. Is there a way to do this? Thanks...I'm trying to create a form that asks 1 question with 4 responses. Each response should cause the user to jump to a particular page, or even to show one text box or another on the same page. I can do this by adding 2 actions to the continue button, but only if the Radio buttons are not contained within a group. I would like users to only choose one of the four options. Is there a way to do this? Thanks...
In Lectora 2005, you could use the new 'on select/change' change action from the radio button properties to immediatly take the user to a specific page upon clicking the radio.In previous versions of Lectora, the radio buttons will need to be grouped (this makes it so only one can be selected at a time.) Then a button or link will need to be made that they click on, which will then take them to a particular page based on the radio group variable value from the choice choosen.
