Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
font 'look' variation problem (thin vs. thick looking)
@andylarson
January 20, 2010 12:00 AM
Never heard of such. Can you take a page that is doing that, put it in a Lectora file by itself, make sure it is still failing, and then post that file to the Files section of the Lounge? Use File menu > Export > Zip and post that. Make sure you make the file Public.
AndyLarson LArson
@andylarson
View Profile
More From AndyLarson
issue with page #'s (total changes within chapter)
January 1, 2010 Reply 0 Upvotes
difficulty with hiding .swfs and keeping in lower layers
December 17, 2009 Reply 0 Upvotes
bullet indentation issue
December 16, 2009 Reply 0 Upvotes
Join The Discussion
Sign Up Login
