FLV Audio Events
January 18, 2011 12:00 AM
Using Lectora Inspire vX.3 (7167)
Lectora Audio Editor Version 2.0 (to create FLVs with events)
Have a page with 4 separate FLV audio files (with events) on it that are cued to play on a button press.
When running in preview mode the audio events work perfect. Toggle visibilities, jump to appropriate page at end, all that magic.
When published to HTML. Not so much
In HTML the audio events toggle the visibility portions correctly, but then it all goes wrong with the "Go To" page event. They all want to jump to the same page even though they are coded correctly to go to different pages.
I have changed them out. Re-created from scratch. And even set the events to run separate external action groups instead of the built in "Go To" in the event properties.
Same result. Works in preview. Wont work in HTML. Tested on multiple computers. Cleared cache and temp files. No change.
Export the course to CD. Guess what. Works fine.
So the questions is: Why on HTML or SCORM publish do FLV events go crazy and forget my correct links in "Go To" actions. :mad:
