Okay, so i have this .mov file that i imported into a flash doc and converted it to a flv adn set it to streaming, when i did this you get to select what type of controls you want. I choose the SteelAllOver.swf controls. So i manually add the steel controls swf and the streaming flv to my lectora folder and add the player/movie holder swf on stage. When i preview it i see the flash controls and then i publish to scorm and add the same files to the scorm folder (under the correct directory) but when i view it the flash controls are gone?Help!!!
