ben (or anyone) correct me if i'm wrong...i'm wishing the holiday was a little longer at the moment...
could this be because you're acting upon a lectora variable, which then acts upon the button? i'm thinking you're not going to see an immediate change unless the page is reloaded going that route. perhaps setting the visibility of the button from flash will work for you (eliminate the lectora variable). you'll need to target the html name of the button from flash.
