Flash to Lectora not working
Thank you, thank you, Greg. I would not have known about the web server part. I also discovered that the same image on each page actually has a different HTML name! That was fun.Good news and bad news: I got it to work on Flash files where I just have a standard swf that plays and ends with the AS to hide the image in Lectora. It only worked when I took out the if statement and just used the getURL code. Yippee!However, it does NOT work (using your whole code or just getURL) with a Flash file where I stop and require interaction from the user. I have tried adding that code to my count on the interaction (if{count==x){ getURL, etc.) and putting it on the main timeline (like the ones that work) and having the counter gotoAndPlay that frame. It doesn't make sense why one way would work and not the other.
