Flash swfobject not working
September 29, 2006 12:00 AM
What version of Lectora are you using? I believe in the most current version (2006 SP4) if you import an animation using the animation button the published version embeds the animation via javascript. That makes it so you don't have to click on it to activate it. Anyway, that means you don't have to use the swfobject anymore and you can use the parameters tab in lectora to pass parameters to your .swf. Hope that helps.What version of Lectora are you using? I believe in the most current version (2006 SP4) if you import an animation using the animation button the published version embeds the animation via javascript. That makes it so you don't have to click on it to activate it. Anyway, that means you don't have to use the swfobject anymore and you can use the parameters tab in lectora to pass parameters to your .swf. Hope that helps.
