Flash Security Settings -- FLV audio files
June 22, 2009 12:00 AM
MRWALLACE Wrote:
Yes, the security settings is what I meant, sorry about that
However, where exactly do I right-click on the screen if it's an audio file that has been converted? The audio file isn't an actual visual/physical object on the screen that you can click on, correct?
________________________________________
I should have been a little more clear. You are correct that a FLV audio file will not have a clickable object. In that case you would need the URL to go directly to the settings support pages to address the issue. This may all be a mute point if the correct version of Flash Player is used. I am still developing my theory as to why some of our users were having problems, and it seems to boil down to the player incompatability more than the security settings. Although when some users changed security settings it allowed the content to play.
Below are the links to the Flash Settings web page and the subsequent Security Settings Panel if you can not right click an object to set your browser.
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager.html
http://www.macromedia.com/support/documentation/en/flashplayer/help/settings_manager04.html
