Flash Preloader not working in Lectora
Sorry you have been having so many problems.I have been developing using flash and Lectora for quite some time and have preloaders built into my flash.First of all I only publish to HTML or SCORM. I do not use Lectora to preview anything because it does not work for advanced Flash. I only preview the index.htm or I use ADL test suite or Reload to test SCORM content.I have used both the native Lectora "animation" object and I have written my own object embed with custom html. The only problems I have experienced is with the directory structures that Lectora sets up. If I embed using my own code I "include" all the files in the title (.as, .swf.....) and make the embed tag point to the first .swf.The only other problem I have experienced is with SCORM. In that it takes a few seconds for the API to initialize then for flash to be loaded if it is on the first page. I always make my load sequence start a few frames into the movie to get around this. Hope some of that helps.SP
