Flash Navigation Interface?
May 17, 2007 12:00 AM
Frames would seem to solve your problem BUT would interfere should you decide to move to AICC or SCORM publish.Since you are using the Flash Object as the slide controller, we might suggest using a Lectora page with both your Flash Object Controller and an iFrame object on the page. The Flash Object Controller would communicate with the iFrame to change the source of the iFrame (change slides). As the host page content would not change (only the source of the iFrame would change)there would be no page reloading.It would require some communication to be established between the iFrame and the Controller and the host Lectora course, but it's not unreasonable. The only real requirement is that the iFrame content be in the same domain as the host course to allow communication.This would work for HTML OR AICC/SCORM whereas the frameset solution would work for HTML only...
