I'm working on some files that were built by someone else and I've run into an issue. I have two courses, 1 that works correctly and 1 that doesn't. The courses have a final assessment at the end of the course that SHOULD be locked until the user completes the rest of that course.
The menu was built in flash and pulls the topics from an xml file. In the xml file there is a line that says
lock_quiz value="true"
Inside flash, it takes the xml information and is supposed to lock the quiz.
As I said before, I have one course that is working perfectly and 1 that isn't. I took the flash and xml files from the working course and used them for the non-working course and that did not help. So, I have eliminated the flash/xml files as the problem.
I am guessing there is something missing in the lectora file that tells the xml that the test is a test. I have checked every variable against the working course and I can't seem to find anything different.
