Flash Frame Rate
The allowable frame rate really has nothing to do with Lectora. The frame rate of most Flash movies is between 12 and 15 frames per second. If you are using Flash FLV videos, you can have some success with 30 frames per second. It all depends on the capability of the computer which is viewing the Flash file.The allowable frame rate really has nothing to do with Lectora. The frame rate of most Flash movies is between 12 and 15 frames per second. If you are using Flash FLV videos, you can have some success with 30 frames per second. It all depends on the capability of the computer which is viewing the Flash file.
