Flash Frame Rate
So I guess what your saying is to not create files over 30 frames per second for Lectora? Also, If I have multiple flash files at different frame rates, Lectora changes the speed of the second loaded file? I haven't done any testing to try and figue out EXACTLY what is going on, but I do know that Lectora has been slowing down my flash files. I can open the actual file and play the lectora from at the same time and it is obvious they are different speeds. Does anyone else have this problem?So I guess what your saying is to not create files over 30 frames per second for Lectora? Also, If I have multiple flash files at different frame rates, Lectora changes the speed of the second loaded file? I haven't done any testing to try and figue out EXACTLY what is going on, but I do know that Lectora has been slowing down my flash files. I can open the actual file and play the lectora from at the same time and it is obvious they are different speeds. Does anyone else have this problem?
