Flash Frame Rate
May 22, 2006 12:00 AM
Tecocat wrote:
television displays at 30fps (and now, with progressive scan TVs/monitors, 60fps).Then it can be concluded as mentioned earlier by Mike_Gthat the hardware plays a role in the fps the machine is capable of. I'd check the video card and find out from the manufacturer what the maximum fps support is. The output of the monitor may also be limited as well.
