Flash CS6 - Lectora 9 - IE 9 Issue
Hi Community,
when I use Flash CS6 to publish to Flash Player 10 oder higher and then use that in Lectora 9 and export it to html my IE 9 always wants to install the Flash-Player Plugin. If I publish to Flash Player 9 it works. If I don't use Lectora it also works.
Does anybody know an answer?
Thanks
Eric
Discussion (1)
How are you all doing this? Are you using an external HTML object for the swfObject.js + an animation? I've published to Flash Player 9, but keep getting the prompt to download Flash in IE. No problem in Firefox. Help!!!
