Flash commands to Lectora not working
I recommend using a timer in Lectora that checks for a variable in your swf file (perhaps one that equals true when you want it to hide and false before) and applies that variable to a Lectora variable. Then you can add another timer run lectora action that hides the item on the condition that the variable equals what you want (in this example true).
LaurelT said:
I have scoured the forum looking for help on this, but I just can't seem to get it to work. I have a Flash animation in my Lectora file and want it to tell Lectora to hide an image when it gets to a specific frame in the .swf. In the past, I used the javascript code, such as:
getURL("javascript:image102.actionHide();");
Now that I am using Lectora 9 and Flash CS4 with ActionScript 3, that code no longer works. I have tried the external interface code, but it's not working, either, even when I test my HTML file on the server:
import flash.external.*
ExternalInterface.call("image102.actionHide();");
I'm wondering about that code, as I just have it on the last frame of my Flash file, as I did before with the getURL. Do I have to add an event listener or call it in another function or something? I am publishing the swf to Flash Player 9 and publishing the course to AICC. I would appreciate any insight into what I might be missing. Thanks.
