Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Flash Background Color
@jeff
August 28, 2009 12:00 AM
It wont render as transparent using the quick preivew mode, but shoudl render transparent after publishing. Did a quick test, and it work okay using wmode = Transparent.
Jeff said:Is there a way to set the Flash animation (animated text) that is within Lectora so that the background is transparent? I tried using the wmode, but that did not work...
Jeff Pfleger
@jeff
View Profile
More From Jeff
Survey Page Not Displaying Correctly
March 7, 2016 Reply 0 Upvotes
html color not displaying properly
May 7, 2010 Reply 0 Upvotes
Goto "Next Page" failing when published to HTML
December 9, 2009 Reply 0 Upvotes
Creating a countdown timer
October 16, 2009 Reply 0 Upvotes
Join The Discussion
Sign Up Login
