Flash animation loop control
With all due respect, I take offense with Neil's reply.I thought the forum was a place to exchange ideas, not lash out at other posters. People have been thrown off the board for the same offense.Lectora uses the embed tag to insert the Flash object into the HTML document. The embed tag is going away. It is a dinosaur.The user was asking of some way to dynamically address the loop parameter of the Flash file. If Lectora added the name value pair in the embed tag one could dynamically address the value, but it isn't added to the embed tag so it can't be easily set.A better question Neil might be, why hasn't this parameter been added to the Lectora flash file 'object', or even better, why hasn't the user been given some level of control over imported Flash files so that these very basic parameters could be addressed?Additionally, if other parameters were made available the user could more easily communicate with the 'object'.Suppose the user doesn't have access to the source file? Suppose he's simply a course assembler who's been supplied the content. What would your suggestion be then? What would your tool of choice be for a suggested solution? Hammer, crowbar, or sledgehammer?respectfully,SB
