I have some embedded Flash files in a Lectora 2004 title that loop continuously when they play.In order to prevent continuous looping, I manually edit the html code after publishing to include a line that prevents looping: anim##.addParm( "" )Is there a way I can make this code work by using the Custom HTML option on the External HTML Object Properties screen to eliminate the need to manually edit html code on mutiple pages each time I republish the program?Edited By: slambie on 2005-12-7 17:23:41
