Flash and Assessments???
If you are not a flash user, Captivate may be the program for you. Captivate can do what you want, but you do have some limits to how customizable the assessment will be.With flash, you can pretty much do anything, if you know actionscript well. But it will take you longer to develop.So, it all depends on the use. Take a look at adobe.com to explain how far captivate will go.But the answer is yes you can do the graded simulation, I've done myself.Edited By: kballard on 2008-7-23 17:8:12
