Fix Visibility Check Boxes
Hello,I'm using Lectora 2007 SP2A... when I have a title open and I click on the visibility check box for an item on the page, I can toggle the visibility. However, if you click the visibility checkbox too many times too quickly, Lectora assumes that you are double clicking the object and will open the properties window for that object. I'd like to see the visibility check boxes fixed so that they only toggle visibility and cannot accidentally open the object properties window.My two cents for the day...
