I assume that by "visibility check box" you mean little eyeball to the left? It should be simple enough for the program to treat the eyeball as a different interactive element, i.e., double-clicking on the eye is not the same as double-clicking on the object name. That would take care of the annoying issue of unintentionally opening the Properties.I too like to flicker my visibility on some objects, so I would prefer that my double-click does nothing special.Kevin
