Feedback and Advance when Correct
I'd scrap the built in functionality and build my own...that's what I always do anyway. You can create your own "Check Me" type button to evaluate the answer and provide results. As long as your quiz question is just an informal one (i.e., doesn't need to report anywhere), this approach works much better, IMHO. It also allows you to do things like give them a certain number of "tries," provide hints, and other "fancy" stuff.I know this doesn't really directly answer your question, but sometimes I give up trying to go through a problem patch and just go around it instead, IYKWIM.Laura
