Feedback and Advance when Correct
August 1, 2008 12:00 AM
ChrystalB-Yes, I do. The feedback works fine if the "Is Correct" conditional is not active. But when the "Is Correct" conditional is active (on the On Click > Next page action) the incorrect answer feedback does not work. However, the correct answer feedback does work...The incorrect feedback will say "INCORRECT. Try again."
