Exit/Close button does not work.
When I put my course in the SLMS, everything works but the Exit/Close button at the end.
The course is in a separate window from the LMS and I am using IE 10.
Any ideas?
Discussion (1)
I'm having a similar issue. In an Oracle Learn LMS using IE 10 and 11 (corporate requirement). In a separate window when you click on the exit button it reloads the title. If I publish with "The published course will prompt to restore the last viewed location within the LMS" setting, the exit button asks if you'd like to resume. Any way of getting the exit button to work? Dave
