Error while Using Flash Command
July 15, 2008 12:00 AM
It sounds like you are running it locally and need to change your security settings.Go here: http://www.macromedia.com/support/documentation/en/flashplay er/help/settings_manager04.html Then select the location to allow the flash file to run.
