error on powerpoint conversion
Hi all,anybody run across this problem with converting powerpoint: Conversion goes fine until it hits a slide and then error's out with this message:"OLEformat.progID:Invalid request. This method only applies to OLE objects."And Lectora basically seizes up at that point, though the save button still works. I can't even exit, I have to kill the program with task manager.Checking the slide where the error occurs I can't find anything unusual there. No animations, there's only three objects on the page, two text boxes and a graphic, no transitions. This happened about five times with different slides over importing about 100 slides. Bit of a pain to figure out which slide is causing the problem and copying the text to a page manually. We're looking at converting a lot of powerpoint files and if we keep having this problem it is going to be a royal pain...Any ideas?Thanks,DaveD
