Equipment to Record Audio
Uhh... ok.Well, if you are using Lectora as your sound-recorder and sound-editor, you are going to end up with poor audio. Most audio requires "tweaking" before it is done. (For example pop-and-hiss removal, room-tone removal, etc.) But if you're stuck with Lectora for everything, your only option is get the best mic you can afford. As far as your events, those can be added to any audio, regardless of where they were authored.Good Luck!Joe
