I have had alignment issues many times when using a table and dropping on top of the table.The table is designed in HTML for text in the cell. The table itself is actually in a text box. Once you start adding code for input fields all hell breaks loose...I would suggest laying it out a different way, or creating a few smaller tables with eh input fields to one side. If you are clever with your placement and borders it will look like its one table.N
