Entry Field problem
I am publishing SCORM files with entry fields in them. Within Lectora the field line up with the tables they are within fine. However when viewing the published file (in a pop up window from the LMS) the fields have moved and are not in the correct place.Anyone with any ideas on why this is happening. Tried with both locking and unlocking position of the fields.cheers
