Entry Box
Hello Bill.
On the left-hand pane of your lectora program you will see the objects of the entry boxes you have inserted. Place the entry boxes in the order of 1st, 2nd , etc.
ie.
Enty_1
Entry_2
Entry_3
Entry_4, etc.
That will be the order followed when you preview/publish.
If you add a Entry box that you want to be the default, then place it at the top or wherever in the order it needs to be.
Bruman
wdhardesty said:I am building a data entry simulation. I have 5 entry boxes on the screen. When I run the program, the cursor always goes to the middle entry box rather than the first box. I have tried to change their order. How can I drive where the cursor starts?
