Entry Box
October 17, 2009 12:00 AM
And to set the cursor in the first entry box,:
When you want to make it so that the cursor is in a specific entry box, you need to make it have the current focus. To do that, first open the properties of the entry box and get the HTML name and the entry name.
Then create an action that looks generally like this:
On: show
Acton: Modify variable
Target: temp
Value: Javascript: document.entry17624form.Entry_1.focus()
For example, if the HTMLname = entry37 and the Entry name was Entry_1, then the value property would look like this:
Javascript: document.entry37form.Entry_1.focus()
