Entry Box
October 17, 2009 12:00 AM
The above tip came from JavaScript Communication Secrets.
I forgot some other tips. The font for all the entry boxes is the default for the page. If you want it to be something other than the normal text block, go to the page Properties and change the default on the Background tab. If that changes the text boxes on the page, you can change them back to what you want by using the normal text box formatting controls.
To learn how to center or right justify the entries and to eliminate the entry box border, see the HTML section of JavaScript Communication Secrets
