Edit Motion Path Start and End Times and Interval
May 18, 2023 12:00 AM
After creating a motion path it would be useful to be able to edit the start time / end time and interval.
Currently if you get something slightly wrong the only way to rectify is delete the path and start again.
Discussion (2)
Yes, I can edit the path points but there is no option to edit the start or end times.
Changed the subject to match the OP request. You can edit the path and the points along the path without starting over. Edit the object, click on Motion Path icon and you can go through the path points.
