I'm in need of some help trying to troubleshoot an issue with insertion of edge animate web window.
When I first inserted the animate edge web window, the window works fine, but when I unlink and delete the file (to edit the edge animate piece) then try to put it back, the audio doesn't work.
I've put the file in a blank title and it works fine.
I've tried unlinking the content and removing it from the tools>resources...saving then reopening and the same issue happens. (The animation and graphics work fine...just no audio.)
