Easy Reset and Undo buttons for drag and drop
August 5, 2019 12:00 AM
Please place these as easy options to select versus having to write actions and variable and/or Java to make it happen.
Discussion (6)
Does anyone have a way to do reset and undo buttons for drag and drop interactions? Please help! Thanks.
Hi,
You should be able to reset a drag and drop question by doing one the following actions:
Reset Question or
Change Contents
I'm not sure if that is what you are after. If you want a step by step undo, that's a bit trickier, can you tell me a little more about what you are trying to do or post an example title here?
Thanks,
Joe
@nstephenson4471 can you put that page into a Library Object and attach it here? I would like to see why Change Contents would not reset that question (for change contents select the question and just leave the value empty).
@wheels ... exactly what does the Change Contents look like? I'm working on an interaction right now... not sure I've gotten is set up correctly.
@schapman1885 Sorry I'm not understanding the question. Executing a Change Contents with the Question object as the target and no value (blank, empty) would reset the question back to unanswered, and move back the drag items. Are you using a Drag / Drop question or is this some other custom interaction?
