dynamic links using js in a SCORM LMS environment (Repost – viewing problem)
September 28, 2010 12:00 AM
Part 1
Hey Everyone
Below here is an article I found regarding dynamic links in Lectora. Basically it allows all the links in a module(s?) to be located in a separate html/js file that is easily updated. Wondering if this solution would work with one js file with many different modules on a SCORM complient LMS (Clarity)? Then I could update any web address in this file and it would update all the related links in all the modules without re-exporting and reposting any of the modules. This would be SO GREAT. Even if I could get it to work per module with SCORM on an LMS it would be helpful. I am absolutely new to Lectora and js. I have worked in similar programs (Captivate) and I am sure with some determination I will be able to make sense and good use of your suggestions.
Thanks in advance,
Stew
