Hi, First posted question. I am in the process of replacing audio clips in a course and hope to duplicate and copy the sync events that have already been established for the old audio clip. I want to avoid having to recreate the timings of events on each slide. Help.
You should be able to replace the audio file without effecting audio events (in Lectora Online). Older versions of Lectora desktop version would burn the events into the media file header. But now all events are associated with the Lectora Audio object and should remain even if the audio is changed.
