Drop down text cut off problem
October 28, 2009 12:00 AM
I'm assuming that you are referring to drop-downs within Lectora's property windows, and not to drop-down menus on screen within your course. Drop down windows within your course can be manually resized by dragging them. Is this correct?
dpell said:On Drop downs with text with a lot of characters, its impossible to see the full text, as its trunctated. Especially when you are trying to figure out two pages with very similar names. Two possible solutions is to have a tooltip with the full text if you hover over the selected option, or increase the the width of the drop down box to the full length of the widest text value.
