Drag and Drop Issue
October 19, 2017 12:00 AM
Hey Everyone, I am currently creating a course that contains Drag & Drop questions. Everything is working perfectly fine with the Drag and Drop functionality but I just had one question to see if it was possible or not in Lectora. Since the images that I am dragging and dropping are rather large, I have a menu to the bottom with the images showing up in a smaller scale. Is there a way for me to resize the image from when it is in the menu to when the user would be dragging it to its destination? Or even to when it locks in on the drop area?
Thanks.
Discussion (10)
Thanks Darrel. I was struggling to find a solution.
You forgot the attachment (I do that at least once a week).
Ok, it might take me a bit. I can easily scale it up but I need to figure out how to scale it back down if it isn't dropped into the correct zone.
Brett, here is something that is close but I'm trying to do this whenever I have a spare minute and there's still some work to do to get it working in all scenario's. I'm posting it in the hopes that Peter Jackson, who's code from another post (http://community.trivantis.com/forums/topic/drag-and-drop-question-snap-back-if-incorrect/) provides insight into hooking into the D&D question, see's it. He could probably figure this out in ten minutes or less. Tim, not to put you on the spot but if you're reading this I'm sure you (or Sergey who I haven't seen post in a while) could also make short work of it. There's a lot of additional potential besides changing the size of the images that we could take advantage of if we get this working.
I probably wont be able to do any more until this weekend (I hope).
That is just what I am looking for. Thank You!!
