Drag and drop audio files
February 17, 2009 12:00 AM
SaffyJust to be on the safe side, put the audio files in a "media" folder in the root folder of your Lectora title project.Then when you want to insert an audio file, click on add audio button [speaker icon] and navigate to the audio.That is just being safe. Secondly, does this work for all types of audio?What audio formats are you using? You also might want to turn off compression just to see fi that is causing an issue. After clicking publish to HTML, and then clicking Publish, you have the "Publish HTML Location" dialog box. The farthest right tab, "Compression" is where this is set. Uncheck for audio just to check.My philosophy is this - make it easiest for Lectora to handle the audio, and turn off all fluff etc. Then go from there.Lastly, we are assuming that you have the audio files set to Play automatically or showing a player control bar correct? Otherwise, you might get nothing... just checking.
