Displaying 0 Digit Place Holders When Displaying a 3 Digit Variable
Not sure if this will work:
But instead of directly displaying the changed variable value, first modify it with an action by adding "00" to the variable value "IF" value is "GREATER OR EQUAL TO' "99".
Then display the newly created variable. This may require a few actions but it should work.
