Disable double click
April 8, 2009 12:00 AM
When someone clicks the IE back button, this code prevents the page from showing and returns immediately to the page where the back button was clicked.
· Click the "Add External HTML" button on the toolbar.
· From the Object Type dropdown menu, select "Meta tags".
· In the Custom HTML box type the following code:
Thanks to Lex_Tensions
