difference in passing score
Thank you. I wasn't aware that the mastery score could be set there, too. It was indeed set to the same number that showed up in the .au file. Does that mean I need to set the passing score in both the quiz and the assignable unit properties? Thank you. I wasn't aware that the mastery score could be set there, too. It was indeed set to the same number that showed up in the .au file. Does that mean I need to set the passing score in both the quiz and the assignable unit properties?
