difference in passing score
We have noticed a problem with scoring lately. I'm using Lectora International 2005 and publishing to AICC. In Lectora, the passing score is set to 80%. In our LMS, the passing score shows up as 75%. When we checked the .au file for the passing score, it was set at 75. Apparently, the default passing score is 75. Has anyone else had this problem? Is the score I set in Lectora not being passed along somewhere, or could it be reverting to the default for some reason? We have noticed a problem with scoring lately. I'm using Lectora International 2005 and publishing to AICC. In Lectora, the passing score is set to 80%. In our LMS, the passing score shows up as 75%. When we checked the .au file for the passing score, it was set at 75. Apparently, the default passing score is 75. Has anyone else had this problem? Is the score I set in Lectora not being passed along somewhere, or could it be reverting to the default for some reason?
