So far, I've learned that using mp3's is the best option for audio. It allows the done playing actions to trigger.
I have a couple problems though. I can't get the mp3 audio to autostart, even though that option is checked. I have to show the controller and then press the play button. Even if I put an action on the page where on show, play the audio, it doesn't work. I even put a timer to wait 5 seconds after the page shows, no dice.
I also tried triggering a second audio to play when the first finishes playing. I press the play button for the first audio, but the second doesn't play. If I try all this on my pc using Firefox or IE, everything works fine, so I know I have it set up correctly.
Any ideas? I really don't want to make a static powerpoint-like course. I'd like to be able to somewhat animate.
