I have also seen instances where the text is still cut off after adding an extra line and deselecting the bullet feature. An additional 'trick' I've used, is to not only add another bullet but add two more - then add a word (my habit is the word 'spacer') for the second bullet, change the font color for that word to match the background - then deselect the bullet feature for the two additional lines. Might sound crazy, but so far it's worked!
