Course with Flash has Adobe Flash Player 9.0.159.0 Issues
The first thing to try is to make sure that you have all the files in the correct spot.
Are you using skins with captivate? If the skin isn't put in the root directory, the Captivate won't show properly.
How are you adding the SWF's? Are you adding them as animations, external html objects?
If you are adding them as animations, make sure that they are in the images folder. If external objects make sure that they are in the root folder.
