Course with Flash has Adobe Flash Player 9.0.159.0 Issues
Thanks for your response. All that was correctly set up. But I did want to post the resolution in case anyone else bumps into the same thing:
The packaged Adobe Flash Player Uninstall removes this key from the registry:
HKCRMIMEDatabaseContent TypeApplication/x-shockwave-flash
Supposedly this key is built into the OS. The key is not reinstalled with Flash Player 9.0.159.0. When the key is added back everything works. It looks like the key is added back in the Flash Player 10 install as well. We aren't ready to go to 10 but by adding this key we can upgrade to the latest version of 9 that includes the security fix. This will keep us running until we go to 10. So magically now all of our Lectora courses with Flash embedded work again.
